there are really 3 setups...
shocks which if removed, the car will still be able to drive
struts that make up the upper part of the suspension (mcpherson strut) entire assembly has to rotate to allow the wheels to turn
then you have our setup that's in the center. as we have double wishbone suspension, the strut doesn't take the same forces on our cars. It does it's job as a dampener, and then carries the spring which holds the car up. That is all the forces it takes, unlike the McPherson strut setup that the turning forces and side loads from the tire are held by the strut.
Double wishbone suspension has advantages of camber with the supension travel, ect...
There are plenty of resources on this around, it will take some reading to understand all the forces going on...
