Hey, sorry, I know these topics come up all the time, but I've searched around a bit and haven't gotten a lot of hard numbers and answers. I'll make it short and sweet, any real quick answers would be awesome. FYI, no mods at all, want to do I/E soon (which I know should be done before turning up too much boost), but I'd like to shim the WG a lil now since everything is already apart.
1. I'm replacing HG right now, not going MHG, is there a certain brand of reg HG that I should go with, and why is that better? Or is a Toyota HG w/ properly tq'ed head bolts/studs fine?
2. Head Bolts vs Head Studs: I'd rather go w/ studs, but do they require a lot of extra work to get in there (like moving motor, etc?)
3. If I go w/ just bolts, is there some reason ARP is better than, say, Toyota OEM parts?
4. Bolt Torque: I've heard between 72 & 85 ftlbs, running a composite HG and no other mods (besides shimming wg), is the general consensus of about 76ftlb ok?
5. Shimming WG: How much boost can a proplery tqed stock HG and the rest of the engine handle for now?
I'm thinking of trying to squeeze 11psi, is that too much (fuel cut? lol)?
And, about how far do you have to shim to get that? (Whats the ratio of amount shimmed to boost added)
6. If I need longer bolts for the WG, whats the info on them (like thread pitch, dir, a good length, etc)
Thanks so much!!!
Thanks so much!!!
