When I start my car it is inside a garage and I must backup... if I put the clutch down (obviously all the way) and attempt to put the car in reverse, I get a noise (not very loud, but a grinding, with vibrations I can feel in the drivers seat) and then it shifts and runs fine.
When I Push the clutch and shift to any other gear (usually 3rd) then continue holding the clutch and shift to reverse it works fine.
However if I pick the clutch up after doing this, then go to neutral I have to do the third then reverse trick.
Any ideas what this might be? It is no problem for me to do this, however It shouldn't be happening and I do not want the problem to escalate.
Thanks!
(If anyone requests I can record the noise, but I do not like making it)
Tom Fraser
Thanks!
Tom Fraser
