(also posted at SF, same post)
well today i finally got to hear my beast fire up,
i had to adjust the cps, it was about 1/4 turn off i aligned the wrong mark when i put it all back together after the hg'..
had to plug up a couple of vacume lines that go into the arcodian hose.. just used some tape,
i also noticed it would crank, then fire, and sounded like all cylinders fire once but then it doesn't continue to run, my dad noticed that with the throttle just barely cracked up it will stay running,
oil pressure started going up right when we got some firing going, it built 45-50 lbs while running.
oh, im not running an afm right now, and also wanted to note thati have no throttle linkage. so could that be why it will idle with the throttle barely cracked?
***sound clips soon***
