setting timing with high idle
RIPDOTCOM
157
Tallahassee, FL
I went to set the timing at 10'btdc on my 88 today but I can only hit 10' at 1000rpm. I know the manual states that it should be at 700rpm so my question is as follows.
what should the timing be at 1000-1100RPM? This was i can set it dead on. I must have it slightly retarded (which is fine since I am using N2O) but for daily driving I would like to have it dead on.
lagged
1991 1JZ
new rochelle
RIPDOTCOM said:
I did jump the proper connectors. Not sure why the idle is high, Maybe from a CAI and egr removal?
does the car always idle high or only when the motor is still cold (normal)?
you must check timing when the motor is up to operating temp.
fix your high idle and check timing again after you figure that out.
RIPDOTCOM
157
Tallahassee, FL
Checked codes and came up with a 41 and 51. Changed the TPS and now I only have code 51 and the idle is spot on. Still have to figure out this 51 code.
