I just corrected the timing on my 87t motor with a timing light. Now the crank pulley mark is hovering right on the 10 degree mark.
I saw this page in the TSRM telling to further check/set timing:
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=IG&Page=20
Can someone explain timing advance to me and when should I, if ever, adjust CPS so that the crank pulley notch is at the 12 degree mark?
Thanks.
Thanks.
