I need to replace my water pump since it's leaking from the weep hole. I wanted to know what causes it to leak from there. I'm guessing there is a rubber? seal that goes and causes it to leak; but besides from that the seal covers the bearings too? So if the seal goes bad, then water gets into the bearings and rust/seize? Can you actually fix this or is it just replace with a new one....my problem is that i have to wait about 2-3 weeks to get a new pump.
Just wanted some input.
Thnx.
Thnx.
