Serpintine Belt
JASONA70
nomnomnom
Oct 27, 2006
743
socal
does anyone know the size of the belt? WITH the a/c compressor, just plain stock size with no mods.
thanks
RHDMK3
that's it!
Sep 30, 2006
447
Salem, Oregon
Just go to napaonline.com. They should have your exact belt that you need there. Just type in your make/model and engine size. It should pull up the belt you need right up.. The engine in question is a 7M-GTE right?
p5150
ASE and FAA A&P Certified
Central Idaho
If that doesnt work just take a string, wrap it around the path of the belt and measure it. Then you know how long of belt you need. Just be sure to get the belt with the right rib pattern
tissimo
Stock is boring :(
Melbourne, FL
mkiv belt... works fine for me.. (I I dont remember if having the 2j waterpumper changes anything, cause I have a 2j wp.. )
daneyan
441
South Florida
i'd assume that u have a 1jz? the belt i got has the part number 6pk1955 on it. it's a good year gatorback nascar belt. bought it from benett auto for $31 i believe.
JASONA70
nomnomnom
Oct 27, 2006
743
socal
this is for a 1jz-gte
i just need the item # and where to get it from, hopefully one of you guys out there have done it before, and yes the 2jz wp does make a diffrence. =\ i wish i had a 2jz wp.
keo
153
RI
the 2jz water pump doesnt make a difference, at least not on my car. hmmm
when i ditch the hydro fan to go e-fan i had to change the 1jz wp to put the 2jz wp, my belt stayed the same length(that includes AC also)
daneyan
441
South Florida
i just gave it to u in my post, check it out.
