hi, i have an 88 usdm sup, and im installing an jdm 89+ gte motor.
my question is, can i re-use the water temp sensors for the ecu and stuff so long i re-use and solder in the connector/ change the connector using apin tool.. reason for solder is the wire insulation is cracked near the connector at a tight bend, figured i would use a better wire .. im decenct at soldering.
already reconneted the knock sensor,
also im trying to switch an throttle position sensor connector one's cracked, and i haven't figured out how to get it apart, this i'll rather not solder that one
also i have yet to be able to find an ecu pin out for an 88 supra. i know i saw an 87 tsrm some where but where it went who knows!
