Sensor for temperature gauge
Ron Jefferson
75
Virginia
Yesterday I was driving on a awful road, felt like a up hill slalom. I was taking it easy since I didn't want to go over a cliff and die. Anyway, it was a 80 mile ride round trip. When I got back to the office I smelled coolant burning. First thing I do is think bhg. I pop the hood and see coolant dripping everywhere. Anyway, I'm freaking out trying to figure out where this leak is. I drove home basically idling since it wouldn't keep coolant and anything thing over 2k rpm sent it towards the red. I started tearing it apart checking hose. Well the culprit was a small 90 degree hose near the cps. I replaced it and all is well, save a few cuts on my fingers. My question is about the sensor for the temp gauge. Is it the small one on near the thermostat housing, I believe its green? My temp gauge is not working now and I checked all my plugs and that one just pulled apart, I'm assuming from the heat. I think its the right one just want to make sure. Thanks all.
gats
Rebuilding... Slowly!
Mar 3, 2009
182
Sydney, NSW
1000 words...
supraguy@aol
Well-Known Member
Dec 30, 2005
4,240
Atlanta
jetjock;1878291 said:
And that hose should be change prophylactically...
You mean swap it out as often as you have sex?
...in that case, my average hose replacement of once/ 5yrs is "overkill"...
Ron Jefferson
75
Virginia
Figured it out. There are 2 1-wire plugs in the same general area. I had them reversed. Swapped them and bam, working well. The hose is holding up like a champ. Thanks for the help guys.
