Who knows an inexpensive place to order all 4 of the targa seals? My targa has sprung a leak and well I would like to do what I can to keep it dry inside and wet outside. Thanks.
mirage83;1987835 said:Where precisely is it leaking? If it's over the doors, then it could be your drip rails that the seals attach to on the sides. If that's the case replacing the seals won't solve the problem, you'll need to remove the rails, clean them up, and apply new sealer when you re-install them. Otherwise water gets under the rails and drips onto your left leg (driver) and right leg (passenger) as well as running down the A-pillar. That sucks when the rain is as cold as it's been lately.
