heh, so I finally figured out which bolt/nut goes where on the lower timing case/water pump.
now on the diagram is says
"Apply sealant to two or three threads of the 10mm bolt end."
now since the only 10mm bolts are for the water pump, I'm assuming that's what I'm supposed to apply sealant to?
as you can see in the picture at the end of this post " Sealant: Part No. 08833-00070. THREE BOND 1324 or equivalent."
what is the equivalent? your standard thread lock at any car parts place?
also, is there anywhere else I need to apply sealant to? I put the two gaskets between the block and cover and the gasket between the water pump and timing cover and am going to torque everything down after I seal the 10 mm bolts. anything else need/want sealant?
