SARD fuel regulator leaking don't know why
Tura_1JZ
Supra down the block
Aug 26, 2009
114
miami
I have 1JZ on a sinlge and I just bought this SARD fuel regulator and I went to install it and leaks by sending line to the unit. I tired both type os teflon and still leaks, now I am running a Walbro 400lph pump but I just don't get it why it leaks, I don't think it's leaking from the hose it's hard to tell I tighten the crap out of the hose. Need help
Radial
252
Norway
check the aluminum hose-adapter and the SARD regulator-housing for cracks.... one of them will crack if you overtighten the hose-adapters.
Aluminum is a very fragile material if you dont treat it right.
Also....use good quality std teflon tape from a plumber, minimum 5-6 rounds of tape.
te72
Classifieds Moderator
6,623
9
WHYoming
If it were anywhere but Florida that this were happening, I would think it to be common sense, but you should NOT drive the car until this is figured out. Might be a good idea to keep a fire extinguisher handy too. ;)
Tura_1JZ
Aug 26, 2009
114
miami
Lol ,yea I had the garden hose handy but Im going to get a Aeromotive regulator. I should of done that from the begining.I read up on other forums of the problems they bring and are not recomended for any single turbo setup becuase they are prone to loose pressure in high spots.
