Hello,
I have a 7mgte 1987 Toyota supra (stock engine internal components) pushing 12 psi with stock everything. This is my daily driver, and the only information I have on the car is a pile of reciepts, basically stating the goods which are a performance shortblock, and overhauled CT-26 (stock 7mgte turbo).
Safely, as a daily driver, I am pushing 12 PSI with a shimmed wastegate (trick to turn up the boost using washers in between the wastegate and turbo). I am using 20w-50 synthetic oil for protection. Is this a safe rating, should I immediately upgrade the injectors, Afm to a Lexus Afm, and k&N, and Apexi Safc fuel management system? Or will that require a tune at the shop. Basically, I want to get everything necessary before taking the car to a tuning shop. What all should I invest in for the future starting at the time of this post?
I am asking for a specific answer to the question; What is the reliable Psi rating on stock 7mgte internals.
Thank you ahead of time.
Respectfully.
Ben
Respectfully.
Ben
