safe boost for 60-1
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Depends on a lot of other things. What fuel are you running, what size injectors, intercooler, IC pipes, what are you using to adjust your fuel, etc, etc. Without all the background, we shouldn't even hazard a guess.
Even *with* all the background information, the proper answer is to put it on a dyno and have a pro tune it while listening for knock with a set of electric ears, then turn it back down a notch and go.
KicknAsphlt
Occasional Peruser
For reference, I was running about 14lbs before I hit fuel cut...and that was on the janky setup that the previous owner used...i.e., stock afm, injectors, and fuel pump. He said he had the MBC set for 10lbs, but once I ran the boost gauge line properly, I was seeing about 14lbs. If it hit 15lbs, it hit fuel cut...and if I went over 3/4 throttle, it hit fuel cut.
