SAFC Problems
cartman
7m powa
Jan 29, 2006
Chilliwack
So I hooked up my SAFC and everthing works fine except it isnt showing an Air Flow reading. I have the pink wire going to the ECU side of the Air flow signal, and I have the orange wire hooked up to the signal wire coming from the AFM. I rechecked all my connections and they are all good, I just hope this SAFC i bought isnt junk. Any Ideas?
Oh its the Digital SAFC. Silver with blue face. not the SAFcII
Supracentral
10
Is it not showing the AFL setting, or the KAR setting?
There's not such thing as "airflow" on the 7M-GTE - you have to use the Karmann signal (it's in Hz).
Example, when selecting the items to be displayed in Monitor mode, the screen looks something like this:
AFL THR
PRS REV
KAR COR
For the 7M-GTE you can use KAR, THR, REV & COR
AFL & PRS can't be used.
Just want to make sure you are looking at the right thing before we move forward with more troubleshooting.
Your wiring sounds like it is correct.
