Ok my friend and I tried hooking up the safc yesterday on my 87 7mgte and I can't get anything to show up on the display. We soldered everything except for the air flow readings which are on male/female connectors.
Everything shows that the safc is getting power but nothing shows up on the display. The car runs also although I had to d/c the airflow readings to make it run normal. I checked those connections and they look solid so I'm not sure what's going on with it.
Here's how I have it wired:
red - pwr
green - rpm
grey - throttle
blue - knock sensor
black - ground
brown - ground/closest to ecu on the one wire
pink - airflow/pressure sensor output
orange - airflow/pressure sensor input
red - pwr
green - rpm
grey - throttle
blue - knock sensor
black - ground
