SAFC Neo wired up.. need help...
AZN MK3
341
Now in the U.S.
ok just got my SAFC Neo wired up and i was wondering if any of you guys know how to tune it... cuz i have no clue... and what should i tune it for... mods are walbro, stock twins, Full 3" exhaust, and intercooler pipings well throttle side, bov, and 31X12X3 intercooler. thanks again
AZN MK3
341
Now in the U.S.
BlackMKIII;910037 said:
Get a wideband before you start touching ANYTHING. Or, take it to a reputable tuner that can do it for you.
so i just keep the settings its on now??? cuz so far i just did the initial set up and all where it boots up and asks you a bunch of questions like v-tech and all...
tissimo
Stock is boring :(
Melbourne, FL
you need a wideband to tune the air fuel ratio. You can either buy your own (~250) or you can rent some dynotime w/ a air fuel ratio readout (~100 an hour). Once you have the air fuel reading, you'll want to shoot for a air/fuel ratio of 11.5:1. In the AFC (not famillar with the Neo) you'll want to mess with the hi throttle map. Just start small until you get the hang of it. For example, if the ratio is 10.5:1 at 4000 rpms, pull a little fuel at the 4000 rpms setting in the hi throttle map, like -4 to -5% then try it out and see what it does and how it effects the ratio. Then adjust accordingly.
Im bored at work, lol
AZN MK3
341
Now in the U.S.
oh ok... thanks... now i just gota find a decent tuner around here... dammit... but i'll prolly get it done by friday cuz im about to go out of town for a while and i just gota park the car at my mom's house...hehehhe... oh wellz...
AZN MK3
341
Now in the U.S.
so if i keep the settings now, like as is. will i be able to drive it to a guy who will tune it... since i shouldnt mess with the settings now, would the driveablity be a bit harsh...
tissimo
Stock is boring :(
Melbourne, FL
with everything zerod itll drive like it did before you put it in, and is fine to drive to the tuner that way
AZN MK3
341
Now in the U.S.
oh ok.. well what about like when you get in your car can i just start the car up right when i get in or do i have to wait everytime it loads???
AZN MK3
341
Now in the U.S.
BlackMKIII;910765 said:
No need to wait. If the unit is powered, it's working.
oh kool... i thought i had to do that everytime... kool thanks... also just talked to a tuner that would tune my car this friday... so cant wait... i'll keep yall posted on the dyno sheet, later on this week...
