Safc neo help
Feb 28, 2008
192
North Babylon, New York
I wired up a apexi safc neo on my friends 89 supra everything reads except the thr position reading when we try to calibrate it say calibration ok but if he give the slitghtes bit off throtle it say 100% the max voltage was 4.86 any one have any idea on y this is happening?
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Sounds like you may have tapped the IDL line of the TPS and not VTA. Double check that you've tapped VTA. The signal is typically from .5v to 3.5v.
EDIT: I take that back, IDL goes to ground when closed and is open when the throttle is open.
EDIT2: Sorry, I'm not familiar with the Neo, it calibrates the throttle position automatically? If so, then the IDL switch having been tapped might still be a possibility. Make sure VTA is where you're getting your signal and post back.
Feb 28, 2008
192
do u know off hand which wire it is on the harness?
