safc moniter questions....
gixxer750
2jzget comingsoon!
Mississippi
what is your knock level......just sitting and idling.....at 1500 rpm, at 3500 rpm?
also, what is the afm frequence for fuel cut? I want to set a warning level just before this.....
gixxer750
2jzget comingsoon!
Mississippi
ok, I didn't get any answers yet.....
my knocking level at idle is 16-20
my knocking level anywhere but idle is 0......
I turned the boost up to 16, stomped on it, and I saw a 2 appear briefly as the knocking level.
does this sound normal?
S
Slow Poopra 7MGTE
Guest
its probley jsut rich knock, rich knock doesnt hurt your car, are you running real rich at idle? try leaning it out i bet it will go away
thesupraman
Smirker
May 15, 2005
129
Frenchtown, NJ
Fuel cut frequency is rpm dependent. In other words, if the ECU sees 1200hz at 5000rpm its fine, but 1200hz at 3000rpm, it will cut (not actual numbers, just an example). Unfortunately there is no magic number to avoid fuel cut with.
