Safc II part throttle boost tuning
3.0 GT
2JZ Holset Mafia
Nov 30, 2008
381
Franklin, Tn
Hey guys, i have a fresh 7m with 550's, lex, 57trim ct26, exhaust, etc.., and im having problems with part throttle boost running 14.7 afr. On the safc II my throttle points are set at 69L 70H with a perfect WOT tune. All of the low throttle settings are at 0 because it runs right at 14.7 in closed loop. but How can I tune for when i am boosting on just part throttle? And it makes boost at relatively low throttle which is becoming a problem.
giterboosted
cure for the common rice
Nov 3, 2007
597
toccoa ga
Anything for tuning below 70% doesmt matter as the ecu is in closed loop and the safc will just be fighting the stock system, which will ultimately win the fight
mkiiichip
1,434
WI
So its ok to boost at 14.7, as long as your not wide open? That does not sound right.
SupraSean
SPRASEAN MTHRFKR
Mar 3, 2009
487
Pittsburgh, PA
I blame a poor tune on the safc2 for my engine melting number 1 piston. because in the attempt to get a good all around low and high throttle tune,,, it leaned out at full boost wot... 17.4:1 Afr's and 16 psi from a t61 dont mix,,,,,,:( oh well such is life,,,, Take that car to a tuner :)
