So i hooked up my safc tonight and I was just going through the settings and stuff and getting an idea of the layout; so I went to the Car Select menu and set that up.
I set it to 6 cyl with the arrow facing northeast, which means closed throttle is 0v-1v and open throttle is 3v-5v. I assume this correct. Now when i go wide open throttle with the accelerator it only reads 74% throttle position. I went under the hood and manually opened the throttle all the way and watched the SAFC and same thing happened. So i know its not the carpet bunching up under the gas pedal or anything. Any ideas?
