SAFC 2 won't turn on normally
87targa
200
Utah
i wired everything correctly. checked it hundrieds of times. opened the safc to check the plug inside also. wiring is correct.
here's the real problem
when i have the key to:
lock: AFC is on
ACC: AFC is on
on: AFC is off
i haven't started the car to see what happens since my fuel pump is out, my injectors, AFM, and throttle body are disconnected.
I even tried wiring the power to the IGN s/w. with the power to the ign s/w, AFC doesn't turn on at all.
all my other electricals work correctly.
what is wrong? :1zhelp:
it's the black SAFC 2.
