Ryan's 92 build thread aka NashMan
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
well as some of you guys know I used to have old build thread about my old 86.5 race car she has bean retired
but I now started to graft parts onto the 92 and many are on there just not going let it all slip out yet
I said to my self I would not make build thread but after reading Reign_Maker thread maybe you can push me so I can complete mine faster
what I have done so far that will to tell
I got my dual filter relocate in and ditched the stock pressure bleed and running 2nd Gen rx7 turbo oil cooler
removed all my abs lines and fuel lines reason being is abs is gay and Kaaz 2way lsd triggers the abs all the time scary shit when drifting or just reg racing
since my ffi is in the way of the batt it's going in the back with taylor box and kill switch ECT blaa blaa blaa
getting my turbo re done at precision turbo and is going to be beefed up to be able to run no bov at racing event's all so going to have my bov on solenoid so I can turn it on and off if I wish
so this said so far I hope you guys enjoy this thread and the wacky ideas I have
I might make mod list later and post some pics
here is some pics of what it used to look like
cheers Ryan
NashMan
Aug 5, 2005
4,940
17
Victoria BC
no i had to choose between the 2 so the 92 won
that and the other cars shell was um to race car ish for me now hell i had no heater in the 86 it was riped out
NashMan
Aug 5, 2005
4,940
17
Victoria BC
well this is some what my mod list and plans
mods list
stock bottom end
single feed -10 fule line
aermotive a1000 fule pump and reg
aermotive fancey tape fule filter ( thank ij)
aermotive fule pump contorler
trans dapt tiwn oil realocate
lots of an fitting's and steel briad lines
blistain shocks
eb springs
st sway bares
nm custom end links
nm custom shifter with hurst pistol grip
nm custom intake manfold
nm custom exhuast wiht burns muffler
and much more
ati damper
titan cam gear
greddy t belt
unortha docks pullies
alt drop down braket were the ac was
batter relocate /yellow top/ph gold breaker/marso switch/
auto meater gauges
oil temp
oil persure
water temp
fule persure
shifte light
greddy egt and boost
percion turbo custom specs t 67 ish
e gay manfold
tial 46 wastegate
tial 50 mill bov/blitz dual drivex2????????? not sure yet got both
perstion trubo 850hp ic
rc 850 cc injectors
lipp fule rail
kvr drilled rotors
nm custom brake lines
F 235 4517 kdws R 275 4017 kdw's
momo stering wheel
maft pro
apexi avcr
greddy full auto timer
plx m300/ aem wide band kit ?????? not sure yet got both
nm custom rear carpet
kz thottle body 90mm
nolgiy hot wire's
lipp valley cover
heater relocate
porterfeild brake pads
abs removed
greddy oil catch can
nm custom sumped fule tank
drive shaft shop aulimin drive shaft
kaaz 2 way lsd
zex perspool no2 kit ( have not bought yet cause car doe snot run yet
nx ic chiller not sure if going to use
zex perg
rx7 t2 oil cooler
ac removed
custom 180 amp alt
momo pedales
12 pound cluthc master fly wheel
act persure plate
hpf brozen cutch
hks stopper gastket
bc spring and tie retainers
nm custom vavle covers
nm custom lower t case cover
soild motor montes still have to buy
obxr sicone rad hoses
felx alight e fan
cfs racing rad biggest drop in
nm cusomt traction arms
well this si all ic an think of
NashMan
Aug 5, 2005
4,940
17
Victoria BC
here is some miss pic i have so far
my pcv and oil relocate and ffi and custom vavle covers
NashMan
Aug 5, 2005
4,940
17
Victoria BC
well my ffi base plate is is done nice and smooth
so now all i have to do is make the rest witch should be easy
here is trick to cut alumin very fast and stright use a skill saw or table saw cut's it like butter use mealt base blade or high teeth count wood blade boother work just as good don't use ripping blade thous cause teh thel are off swiped
i am kinda on hold for now caus ei got to pick up some carpet for the back of my car then i can run my battie box ect
well back to the grauge i go since work is done it's beer time lol
NashMan
Aug 5, 2005
4,940
17
Victoria BC
well my alt has bena moved so it's no big deal to me i have to use some jb weld thou on the injecotr holes cause there tiny pit's in it witch may cause a leak but it is no big deal
NashMan
Aug 5, 2005
4,940
17
Victoria BC
well my new fly wheel is here keep missing the bloody oops i droped you shit man aka ups
think i may drop the tranny some time this week but frist i have to blance it
all so i am maken 2 lapping tools if some is intrested in buying one
cheers ryan
NashMan
Aug 5, 2005
4,940
17
Victoria BC
well looks like my wish will come true i should have my fly wheel on thurs day so i can at lest do something
NashMan
Aug 5, 2005
4,940
17
Victoria BC
well my intake is comeing along
just cut it so i can un warp it the rest should be done today mabey if i have time other peoples cars come frist
all so got all the sound deading out of the back trunk so i can lay new carpet since it will look may better this way whe i monte my battier and other fun stuff
cheers Ryan
NashMan
Aug 5, 2005
4,940
17
Victoria BC
ooooo got my fly wheel xtd one seam's to be pretty nice it's beefy yet light at the same time
looks lieik trannies gonna be droped out
and cracked open since i have some leeks and such no big deal thou
all post pic's later tonight
NashMan
Aug 5, 2005
4,940
17
Victoria BC
well i never got around to pulling my tranny but i did make way on my ffi
see mine is slighty difften then other's
all let you look and see can you notice the diff between teh other that have bean made
ps she now is level as stock we will see as soon as i make the surge tank so see if she is still flat
cheers ryan
