RUST! Everywhere 8k estimate fix. Need some Help with questions on swap. Please.
Turbo Habanero
4,229
Tucson,AZ
So i have a 89 turbo Targa that has rusted insde and out from engine bay to tire well. it was everywhere sadly.
A Shop here told me a rough estimate about 5-8k in work I don't have that kind of money.
But i do have a 87 N/A Manual Hardtop sitting around... So my thoughts is to put my motor and R-154 in the 87 shell.
But im not sure on everything i need to do I know
I need a 87-88 Turbo ECU/5speed and Harness. Anyone got this i will buy
I need to change some sensors or plugs on a few things i believe i just forgot whitch ones was it Knock sensor and Cam postion sensor? does the part need to be changed or just the Plugs on the part need to be changed? I will need to take Driveshaft and LSD diff and fuel pump correct?
The N/A car is not TEMS or ABS I was planing on coilovers any how. and ABS well i guess my car will be even lighter now.
Anything i missed or any help or comments or wanted and very much appreciated.
About the cars
89 Turbo Targa TEMS/ABS. 5speed
Motor and transmission/Interior into
87 N/A Hardtop 5speed. No ABS/TEMS
Thanks Jordan
S.A. supra
2,405
Buda, Texas
Lol yeah. Strip it down to the frame. Swap over all the harnesses, and everything that goes connected to them. Basically turn your 87 into a 89. It's a lot of but not hard.
IBoughtASupra
4,455
Queens, NY
That is some bad rust. Is it that bad or it could just be surface rust that some grinding down and POR 15 could fix.
I bought a cars from Virginia, Pennslyvania and New Hampshire and all are rust free. How would a car from a nice weather place have so much rust? Maybe a bad shop trying to rob you?
Turbo Habanero
4,229
Tucson,AZ
There is alot of surface but there is some spots that has gone stright through the body. i can see straight to the ground in some spots
Turbo Habanero
4,229
Tucson,AZ
IBoughtASupra;1711981 said:
Look under the engine bay, what are the color of the plugs by each strut tower?
its a grey plug :(
So if i a full 89 swap into a 87 what all has to be taken to make it work? I.E interior/stereo stuff things of the sort.?
Backlash2032
1,823
Nebraska
Just source a yellow plugged ECU and harness and a few sensors and you should be good. Way easier than swapping the entire body harness or making a custom body harness connector.
Turbo Habanero
4,229
Tucson,AZ
How much does harness and ECU go for normally? and what sensors do i need to change also there are clips that i need to change on the 89 motor witch ones are they?
