queenskid,
the verbage useage is not the issue.
the 2-step you speak off will be a crap shoot.
ALS has granular control of when the ignition event takes place. The Bee-R, this doodad, don't. Or in other words it could be the most agressive timing that the system could see, chewing your turbo up in time flat. IE, it will build the same boost regardless. No way to lessen it or increase it.
That is why the people with knowledge will run ALS or a form of it as too much boost, even on DR will cause wheel spin. So then you need to decrease boost creation if you are not hitting wastegate opening which is only possible by advancing the ignition event.
