Running too Rich???
7m2ner
Boosted MA70
Jan 26, 2006
82
Schaumburg, IL
I just recently did a 7mge-7mGTE swap, and i have noticed, when i get on it, i get some smoke at first from the unburned fuel, then you can smell the fuel in the car from it running so rich, wat might be wrong??? please and thanks
Supraholic
Houston, TX
can you smell fuel in the cab? then you probly have a fuel leak.. check the fuel pressure damper area, and fpr area for fuel when engine is running..
7m2ner
Boosted MA70
Jan 26, 2006
82
Schaumburg, IL
yea you can smell the gas in the cab at times ,but i will check that, and i will have to see wat i can find, but thanks man
ViR2
Supraniac
May 20, 2006
932
Lithuania
www.hpaddict.eu
if u're smelling gas inside, there must be a leak, check fuel pump external lines, mine ware coroded so they ware also leaking and I could smell gas in interior ;)
DaSuprawolf
Im SICK of N/A
Dec 29, 2005
456
ChicagoLand
i was told once before, "the only dumb question is the one you dont ask."
this is what were here for.
o and for the location, i believe its in the rear, i think i seen there while i was under it once? kind of hidden, i could be wrong.
It is under the car, on top of the gas tank. I replaced mine when I did the fuel pump swap.
7m2ner
Boosted MA70
Jan 26, 2006
82
Schaumburg, IL
hey thanks for all of the info, and did any of you guys that have done the N/A to turbo swap have to swap the fuel pumps? or did the n/a pump work fine? cuz it seems like mine is working fine. well thankx agian for all the help
