Ok, We got my cousins HG replaced and now the car shudders pretty bad. It only seems to do it at cruising with my foot lightly on the gas. When I let off the gas or floor it everything is how it should be.
CEL is giving me code 25.(running lean; or bad O2 sensor maybe)
The engine free revs in park beutifully, no bog or hint of anything wrong. Its only when the cars in motion at like 25+MPH that the shuddering happens.
I figured I could trick the computer by advancing the TPS and making the engine think it was getting more air so it would give more fuel. Nothing changed so I put it back.
I got suspicious and started to think the driveshaft could be the cause of vibration. checked the driveshaft. Pushing on front shaft near the center bearing theres about 1/2 CM of play.
Anyways PLEASE HELP ME!!!
