Running lean as hell ???
Arabian
5
Kelowna
K, its a 1992 7mgte, port and polished head, intake exhaust, an aftermarket t3 turbo, 550cc injectors, walbro 255 fuel pump, intake, 3"exhaust, aem A/F meter with wide band 02, i put in a brand new coolant temp sensor and a new ECU, So whats happening is... Doesnt run worth a shit, runs lean and then dies... any suggestions?
Turbo. Targa. Life.
SupraMania Shirt Slinger!
Apr 16, 2005
1,709
O'Fallon, MO
www.geocities.com
Cracked Intake Manifold (weld it, replace it)
Bad intake manifold gasket (replace it)
IC Hose popped off (put it back on)
IC Clamp/coupler cracked (replace it)
Injector not receiving signal (hold mechanics stethoscope to injector, you should hear a steady click)
Injector not firing (hold mechanics stethoscope to injector, you should hear a steady click)
Bad O2 sensor (replace it)
:dunno:
Arabian
5
Kelowna
Today i jumped my FP to run on constant 12v, and it ran a lot richer @ normal temp but random spikes kept occuring. Any ideas why it would have random spikes from around 14.7 to 17 and off the scale?
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
where did you buy your fuel pump? Was it Ebay by any chance? do you have a fuel pressure gauge? what does it read at idle without boost reference? does the pressure bleed off as soon as you shut the car off?
If the answer was yes to most of those questions buy a new fuel pump from a place that specifies GENUINE WALBRO....ask me how I know?
Arabian
5
Kelowna
K its a genuine walbro from suprastore.com i have a fp regulator but its on its way. So you believe its due to a fp regulator lacking..... onlything that baffles me is the stock fp regulator is still gonna put out stock fp yeah..... and if im only idling then why the hell would it matter if i had an aftermarket fp regulator or not. I lean out @ normal operating temp @ idle
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
yeah I wasnt questioning you FPR. It turns out my Walbro wasnt bad Im now suspecting my FPR.
But in your case its hard to say why you are leaning out. Definately the post above gives you some places to start looking.
