Well I got my supposed JDM motor for my car last week. The motor was an earlier motor, so I swapped some things out and changed things around to make it drop in. Got the motor all dropped in and connected up, car fired right up but as soon as the temp gauge starts to move as it heats up it just keeps going and pegs the temp gauge.
I tried burping the cooling system, I tried flushing the cooling system out. I swapped thermostats, everything worked fine that I put in from the old motor, I tried all the things I could think of too fix it and nothing worked.
When the temp gauge is pegged the car will sit there and idle and run for the most part fine. Well it's running with the temp gauge pegged I can lay my hand on the valve covers and it's not that hot. I don't think that it's running as hot as the gauge is showing but I don't want to take any chances. If anyone has any ideas of what it could be, any help would be greatly appreciated.
I was getting code 51 which is the Switch Signal. I'm not sure what that means but hopefully one of you knows what could be causing that code.
It sucks though cause I wanted to get the car running before I moved but with the problem I'm having I can't drive it, so as of right now I'm about 1000km away from the car so I can't rush out and try things on it, but I'm going back to get it running in the next few weeks.
