Okay my car can idle forever and a day and never heat up but as soon as I start driving it gets hot, then boils over ONLY when I turn it off. Now I have already checked the water pump(water is flowing through the radiator) which also means the thermostat is good, I can rev it up while it is in place and its fine. Engine temps are 220:water pump, 210:top of radiator, 170 bottom of radiator, 200: valve covers, 150: intake. I did a compression test and all is good, there's no foam in the radiator and I just replaced the radiator cap. It seems like its the factory 7m na radiator and electric fan, is it likely that a 7m radiator can't handle the pressure from a 1jz? Does anyone know how much of a difference in temp the coolant should be from the top hose to the bottom one? Thanks in advance
