I was wanting to know what kind of setup needed to run this fuel? I have these mods, lexus afm, t4 turbo .70 cold side, .68 hotside, internals modified and fuel as well, with a hks s-afr for piggy back comp. Any help would be appreciated!
grimreaper;1448354 said:search figgie... he covered this a few years back. basically fuel rail has to be treated and injector size needs to be increased even on a full stock setup. Fuel pump needs to be re considered as well...
It REALLY leans out the af ratios with 20-30% mixes when compared to regular pump. Careful when tuning!
To convert
well this is tricky. I am on standalone so it is easy for me to switch from Alkie to Gasoline.
but the basic premise is that with e-85, the car needs about 25% more fuel. Stock the car is 440 injectors meaning the next higher up of 550 will do. Do this without the lex AFM and you have perfect stioch for e-85 Of course run gas and you will run rich.
As for the conversion this is where it gets painfull.
Any aluminum or zinc plating, GONE. Fuel rail needs to be anodized at the very least to survive. The head is a non-issue as the fuel does not stay in the head. Fuel lines replaced with alcohol comptabile lines. For stock power level an SX fuel pump will work. They are stainless internal so they are alcohol compatible. Walbro is NOT and Niether is the AEROMOTIVE FUEL PUMPS!. Fuel pump has to live outside unless the fuel pump is sealed and made for e-85 (see ford or GM for pumps). Reason is that in the gas tank the gasoline makes way to rich a mixture to ignite. Things change with alcohol as it is near a perfect mixture to ignite.
As for pinging. At 105 octane unless you screwed timing up badly nope.
-Figgie
AFR is Lambda * stoich value of fuel.
Lambda is independent of fuel value.
If the engine develops max power at 0.82 Lambda, it would also develop max power at that Lambda with E85 (or close to it).
0.82 Lambda with race-gas is 12 real AFR (14.7 * 0.82). With E85 the "real" AFR is (9.7 * 0.82) = 7.92 AFR. When leaving the LM-1 set to gasoline, it will show instead 12.
For tuning purposes most people don't bother with changing to the correct stoich value, as they are used to the gasoline AFR numbers.
The fuel flow to reach that "gas" AFR is if course very different.
Also, don't forget: the ign. timing curve should be optimized for E85, as the burn characteristics of alcohol are different than gasoline.
-Klaus
grimreaper;1448768 said:your basing the assumtion that because it worked in an mr2 that it will work exactly the same in an mkiii supra. Thats not how the tech section works.
steveaw11;1448904 said:now there is 1 thing I would wonder about in the compatibility regard.. our fuel pump filter socks.. they are a plastic material. It may not like Ethanol.
grimreaper;1448921 said:could have sworn this was about running a different fuel on a stock hardware supra (pump, lines, tank, rail, injectors). again, your word of mouth from some other forum about what some OTHER guy did is great but not what ANYBODY should base their decision on. Thats not what this section is about. If YOU have run it by all means post what your outcome is/was and the like... 3rd hand experience is BS when looking for HARD facts when it comes to something as critical as the fuel system.
