RSR GT-2 ground clearance?
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Mine's not lowered, but I have scraped going onto a ferry once, but that's to be expected with just about any car going down a steep incline such as the ferry in question. Other than that, no scrapes, but once again, not lowered either, I'm in 4X4 mode ;).
mhopemk3
The CT install SPECIALIST
Jul 13, 2005
762
Jacksonville, FL 32277
Mine is lowered with KYB's and suspension tech springs.. The lowest point on the exhaust is almost right under the rear tires. I have only hit it once coming out of my driveway at the wrong angle and a little fast. Things you will have to learn about your car though.. No problems with speed bumps etc..
mattcosta7
Dobbs Ferry, NY
I have stock suspension with 17s, and I scrape a very little, but ONLY going up a hill where I once scraped my stock exhaust (only do this when necessary, otherwise I drive 2 miles out of the way to avoid this hill!)
Ill take a picture of the exhaust piping and post it here to show how ground clearance is at stock height
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Oh, I'd also like to add that the area where I scraped wasn't even the lowest point. It was right where the muffler is welded to the piping where I scraped going onto the ferry.
mkIIIman089
Ohio
How low below the subframe does the Dragger hang?
Seems kind of stupid to me to change such a major component of it instead of just shortening the hangers.
mhopemk3
Jul 13, 2005
762
Here are a few pics..
7" from the ground behind the front wheels!
