Still having issues when it comes to loading facebook, tracked it down to the fact that static.ak.fbcdn isn't loading at all. If i use https, then FB loads, because the SSL servers are on a different IP.
So, tracert with static.ak.fbcdn.net reveals that everything is fine up until the point where Level3 hands over to latnetserviss.lv - at which point it reports 'destination host unreachable' and drops back to a command prompt, although, why i'm being routed via fucking LATVIA i don't know.
Now, if i use my proxy, then i can load it, but half the time, my proxy isn't loading either, so is there a way i can reach FB via some other means?
I can setup a network okay, but the larger, ISP level stuff, i'm lost on.
