Roughly where am i HP wise ?
Royalmaas
22
Norway
For some people this might be a stupid question, but i gonna ask it anyway :naughty:
Recently i`ve been lurking around here trying to find people with the same setup that i`ve got, and maybe get an idea on what power i am looking at atm..
Well here is the "Specs"
Stock CT26
Greddy Profec 2 @ 0.8bar / 11.5Psi
2.5" No cat from Turbo and back
Open filter
MHG
ARP Studs
Everything else is basically stock :nono:
Maybe also worth to mention the engine was overhauled in 2006, so i guess its been driven bout 25k Miles after that.
All comments is appreciated !
Cheers, Roy
radiod
1,342
Abbotsford, BC
Turbo Habanero;1875929 said:
Yea its hard to say only because of your exhaust for me.
Most would go with a 3inch setup and mandrel bent.
Is yours crush bent ?
Either way, his 11.5psi is the major factor of what's going to be giving him power. The largest reason you'll see more power from a better flowing exhaust is because you'll make more boost with less backpressure on the exhaust side of the turbo. I don't think you'd see much of a difference at all between a 2.5" and 3" exhaust with his sort of setup.
