I have a question.... when I am in neutral and the car is idling, the engine will kinda kick once in a while. It is a 1990 Supra Turbo. It seems to do it more when engine is warm. Just wondering what possible things it could be? Thanks
Could be a vaccum leak! Also when it kicks how much does the motor move I am just wandering because if it is alot you may want to look at your engine mounts to make sure they are still good. Just a thought but alot of the older Supra owners on here will be able to give you a little more insight on this. I am just pointing out the obvious to get you a good starting point til they can get to you. Also does the idling change any or does it move around.
