More than likely when the snow is gone, I am thinking of going with this setup for my new tires. These are 13lb wheels, 11lbs lighter than stock  Anyway, my first set of tires are going to be stock size, when those are worn out I'll have enough feedback from the car to decide whether or not I want to upgrade the tire size or not... if I do, 245/45R16 is available and will fit perfectly
From my calculations, 16x8 +48 should fit perfectly over 16x7 +37 of stock.. extending only a few mm outwards and 24mm towards the struts, which has a ton of clearance
Just wanted to see if anyone else has tried something similar...
