what clearance should I set my ross pistons that I am going to have to get to?
Also, where is the cheapest place to get a set of .017 over pistons?
gixxer750 said:I know that a lot of people have gotten slap with ross's recomended clearances. I'm actually looking for answers here from some of the known high hp people like mallorynx, IJ, adjuster, or some of the others here that I may have left out
bigaaron said:I am one of those people who went with Ross' recommended clearance and I do believe it is too much. They are much louder then JE. I think that Ross is a few thousandths too much on their clearance specs. The problem is that if you go too small it could expand enough to seize up in the cylinder.
rakkasan said:I appologize for the slight highjack, but the ideal clearance for is JE's .004, correct?
bigaaron said:It starts at .006" minimum for Ross, but you are supposed to go more for high boost turbocharged or supercharged engines.
Ross has a little bit more clearance for expansion then JE.
Ditto!bigaaron said:I would go .005 or .006, more if you plan to run nitrous.
siman said:Ross may use a special blend of aluminum that might expand a little more than your average aluminum matrix metals in other brands.
This may be why they call for a little "bigger" tolerance than the other brands ?!
But thats me speculating. I am not a metalurgist in any way....but I did sleep at a Holiday Inn last night.
-Jonathan
