Romoving the front body harness....
rakkasan
Currahee!!
Fort Campbell, KY
I'm trying to remove the front body harness completely. To get it through the whole in the engine compartment (where it enters near engine compartment, by the battery), I'm assuming that you have to disconnect it from the fuse panel inside the car. Is this correct or do you have to disconnect it from the fuse box by the battery?
Idealsupra
Orlando
www.tampabaysupras.com
make your life easy and dont do either ;) it will fit out of that hole WITH the fuse box if you take the fuse box cover off and take out the larger 30 and 60 amp fuses...... then just fish it out...
rakkasan
Currahee!!
Fort Campbell, KY
What about the box itself? Are you saying that the harness disconnects from it?
Idealsupra
Orlando
yeah it COULD but you dont have to do it that way....unbolt the fuse box from the bay...and then take the cover off and the larger amp fuses out of it...and it will fit through the harness hole...barely...but it fits...just snake everything through ....
