Sonex2000 said:
I fucked my car again.
Rod knock happened.
Any suggestions as what I can do?
Yes, tell us why it happened!
I would really like to know why.
Many will say you did not have enough oil in there, BUT I know some are getting rod knock who have enough oil in their motor.
Another reason may have been from having compromised oil because you once had a BHG and the oil and the coolant mixed, and bearings don't like milkshakes as a lubricant.
Or did you build with improper tolerances? If you had too much clearance between the crank and the bearings, that too can lead to rod knock.
Was your oil pressure fine before this? If for some reason you had low oil pressure, that too can be a leading factor.
As far as what you can do now with your car, I will type you another post with your options. I have that prewritten somewhere but I have to run outside now
