i dunno how but i lost one of my rod cap,should i just change the cap or the whole piston?can i use a cap from a 7m to a 6m crank?
Supraboostin said:...should i just change the cap or the whole piston?...
I second that. If you change the cap you have to change the connecting rod as well. If you lose a cap, you need a connecting rod with its rod cap. You don’t necessarily need a new piston. I am quite sure you can use the piston you have (unless it is bad for some other reason).z1turbo said:You cant interchange rod caps, they are line bored.
I know from my own experience & measuring them with my mic’s that a 7M-GTE with either a 6M or a 7M crank use the same pistons & connecting rods.Supraboostin said:... can i use a cap from a 7m to a 6m crank?
chevyeater said:What? The 7M pistons use full floating wristpins. Remove the snap ring from one side and turn that side down, the pin will fall out, unless it has siezed in wich case you'll need a set of pistons anyway.
Supraboostin- You'll need a new cap and resize the big end of the rod. Same goes for if you haven't kept the other 5 caps together with the rod they belong to (resize them).
Nope, I won't burn myself.lzalusky said:You actually can remove the pistons yourself. I heated some vegitable oil in a pot and heated the piston/rod for a couple minutes then tapped on the pin with a dowel. The pin slid right out, just be sure you dont burn yourself in the process.
why did you choose vegtable oil over water?
Supraboostin- You'll need a new cap and resize the big end of the rod. Same goes for if you haven't kept the other 5 caps together with the rod they belong to (resize them).[/QUOTE]
The blind leading the blind again. A rod can be resized to zero tolerance so get another rod cap, and take the whole set to a machine shop and get them checked, and resized to zero tolerance. DON'T put that engine together without resizing all the rods back to zero tolerance. The 7mgte needs tight clearances, and even if worn to within specs it will wear out of specs sooner than later. Why do it 2x. Read my thread on how to avoid or minimize rod knock. You are teetering on having to do itall over again if you don't heed my warning.
Anthony
