Rod Bearings 1165-CP 25mm | Now What
sandusky1977
4
Lansing, MI
Hey all, I bought a basket case, and I'm trying to piece it together and build a motor.
Currently it's got a set of 1165-CP 25mm Rod Bearings, and when I search them they state they are 25mm undersize? This is a total foreign concept., as I see I can order standard, or 10, 20, 30mm over.
Can someone tell me if I'm running the 1165-cp 25mm, now, what should I replace it with?
You need to either take it to a machine shop or measure the crank and block and bearing and figure out what size you need.
