Rod Bearing Size Question
supraguy31
626
Pembroke, NC
Ok all, Here is a good Question that Im sure some of you can Answer.
I had to replace the Rod Bearings in the car since I was getting alot of Clatter. When I took the #1 Clyinder bearings out, I noticed that there isnt a Size engraved on them. All I see is the #2, #3 #4 on some of them. Most have the Number 3. Now when you look at the Small number that Is engraved, The #3s are the same, so on and so on......
Question is what Size rod Bearing do I need to get in order to make sure I have the Correct Clearance. I hear that all of them as Suppose to be the same. Basically, What do I look for when Im looking at the rod Bearing to get the Size.
Thanks
Robert
