Wondering how I check the rod bearing clearance. And what are the #'s for the clearances.
Yellow 13 Lurker Apr 4, 2006 2,308 0 36 Fairfield, California May 2, 2006 #1 Wondering how I check the rod bearing clearance. And what are the #'s for the clearances.
J JT87NA New Member Mar 30, 2005 171 0 0 42 SLC, UT May 2, 2006 #2 Yellow 13 said: Wondering how I check the rod bearing clearance. And what are the #'s for the clearances. Click to expand... Plastigauge, the clearance specs are in the TSRM
Bishop92t Supramania Contributor Apr 18, 2005 773 0 0 USA www.ma70.com May 2, 2006 #3 Make sure you use green plastigauge as well (don't remember if the TSRM specifies).
