Okay i've been trying to figure this out for awhile now. unfortunatly have not had much change laying around to properly go for a decent diagonsis. Any way
Car: 1987 Turbo 5speed
Problem:
* GREY smoke after boosting, (amount of smoke is related to time and level of boost, longer more smoke, more psi more smoke.)
* Smoke occasionally at idle. (hold gas peddle at about 2K and it blows out after a couple seconds)
* hints of smoke under hood comming around ex. mani and turbo.
* liberal coating of oil in IC pipes
* Have already replaced turbo.
* Smoke smells strongly of oil.
* Coolant levels remain fine.
Have not done a recent compression test but compression was almost perfect 2 months ago. w/ ~3 psi variables between cylinders
MODS: Lex afm w/ 3" filter adapter, 3" elbow back exhaust. pvc IC piping, HKS SSQV, Profec-B Spec II (set to 6(lo) 11(hi) 80% of driving done on low), 550 rx-7 injectors flow tested and cleaned, LC-1 WB, Megan AFPR, oil catch can with NA junction pipe plumped to catch can then to TB port (had it T'd to goto TB and accordian but revised) Charcoal can removed.
Problem:
