rim bore size??
Chaos_Performance
Ohio and Mass
hi i am buying some rims and was wondering what the bore size is on the 87 supras?? thanks
im looking into enkei rpf1s with toyo t1r tires. 17x8 in front with 17x9 outback +35
Sawbladz
1,727
Oshawa, ON, CA
+35 in the rear would be fine but that leaves the front kinda sunk in. The front would be more flush at +25 to +30. Not sure what you mean by bore size. Are you referring to the size of the hole in the rim to make them hub centric?
