Riddle me this
JStoked
646
Edmond, Oklahoma, United States
Ok whats the best way to clean a gas tank that has fuel setting in it for the last 8 years? And yes i goggled it and no i dont have a tractor lol. Tank has been drained and and is siting open to dry it it out. so any ideas to get all the rust out:naughty:
zby67
173
Texas
put fresh gas in and shake the tank? drain then do it again. or some sort of cleaners and a powerwasher...
CT26smoker
223
Houston
Old biker trick:
Put a hand full of 8mm nut in it, and start shaking it like a milkshake.
When your arms are about to fall off, take a break.
Repeat until you see very little or no rust.
Dump the nuts out, rinse with mineral spirits (cheap paint thinner) several times,
then buy a quart of gas tank sealer from someone like Eastwood, and coat the inside.
Or.........
Just spend a few bucks, and get a good used tank from one of the many part-outs going on.
CT26smoker
223
Houston
Just a thought.........
Are you sure it is rust?
Seen some tanks full of brown varnish like substance.
The best way I have found to cut that crap is Simple Green.
JStoked
646
O ya its rust we drained over half of tank of gas out of it and oooo did it smell terrible. Thanks hvy that is some help. And ya this is the take out of a 86 crssida mx73 so im pretty sure no one is parting one out on here.
