I don't usually hang out at forums too much but I felt like tossing up a rebuild thread because of all the help I got and am still getting from this forum. Not just searching for info, but from Jeff Tamulis who has sourced parts for me and to jetjock for the AC info.
So I started from scratch with a used block, a well written set of instruction for the machine shop (a shop that I have dealt with in the past, and know well) and ordered up all new parts. I pick the motor up friday from the machine shop. I'll build it this weekend.
Here's the details:
ENGINE
Used 7M-GTE block
Toyota gasket set
New Toyota oil pump, shimmed.
New Toyota water pumper.
New Toyota 7M crank*
+0.020 JE pistons
Titan HG
ARP head studs
Clevite 77 bearings (Toyota thrustwashers)
HEAD
7M-GTE
5 angle intake, 3 angle exhaust
bowl hogged exhaust side
port & polished
EXTERNAL
MAFTPRO (+SD, +Boost, +LC-1 WB O2)
Turbo (TBD)**
550 RC Engineering Inj.
Spearco IC, hardpipes
3" DP - HKS Dragger exhaust, no cats.
No Lexus in there because of the MAFTPRO. There's probably more but I'm not remembering so well prior to my morning coffee. I'll update and add photos as I make progress.
*I'm building this car as a daily driver, so I opted for the 7M crank over the 6M crank for two reasons. First, it should have less vibration, and second it was cheaper than the 6M crank through Toyota.
** Turbo is still in the works. I will break the motor in on a 60-1 CT-26 but ultimately will upgrade to something a bit larger.
Here's the details:
ENGINE
Used 7M-GTE block
Toyota gasket set
+0.020 JE pistons
Titan HG
ARP head studs
HEAD
7M-GTE
port & polished
EXTERNAL
Turbo (TBD)**
