Resurfacing of lightened Al flywheel
CPT Furious
Now MAJ FURY!
KDOV
Hey guys and girls,
I have an aftermarket Al flywheel that I got from Toysport about middle of '98 so I'm not sure who they manufacturer is, but can you resurface it like you would the stock flywheel or do you have to find someone with a replacement insert?
Gracias... :1zhelp:
kamil
87T Targa
Apr 4, 2005
144
Tucson, AZ
I think your best bet is to look up the stock tolerances in the TSRM for a flywheel and see where you're at with your aluminum flywheel. I would guess that they are manufactured at the lowest end of the tolerance spectrum in order to have the lightest weight, so removing any material will probably make it too thin. If you can't find the specs, take it to a shop and they can look it up/let you know where you're at.
