resonator question.....
rakkasan
Currahee!!
Fort Campbell, KY
I recieved my resonators today, but I have a question about them. They are 3" on the in & out side, but in the middle 12" section, it chokes down to about 2.5". This section is perforated & I assume that there is some sort of sound absorbing material behind it, so I don't think that it will be much of a restriction if at all since the exhaust . Does anyone disagree?
Mr.SelfDestruct
I build planes... yeah...
May 27, 2005
608
everett, WA
the perforated area is usually packed w/ fiberglass.
it shouldnt be too restrictive, but if you dont like how restrictive it is, take one of the resonaters out.
tubbie
Yes, powerful Jedi....
Apr 4, 2005
821
Hoschton, GA
If it goes from 3 inch to 2.5 inch, it is a restriction. Your exhaust is only as big as your smallest section. So effectively you are running a 2.5 inch exhaust with that resonator.
cjsupra90
previously chris90na-t
Jun 11, 2005
1,029
Lakeland, FL
Mark, yeah the bottle neck into 2.5 is going to be a restriction. What kind of resonators are they? I'd try to get them swapped out for ones that have a 3" core section.
Depending on make, I might be able to tell you someplace local that will swap them out for you if a 3" core section is availible.
